So will these tires work for me?
jonlorio
i know i know, not another tire thread huh?:sly
i'm currently looking at the 325/60/20 toyo open country AT's for my factory 20" wheels on my '06 king ranch FX4. i plan to put the 2" leveling kit on when i swap out the tires. Are these tires gonna be too big or will they work? the tires have a max load of 3195lbs, so they should be fine there right?
if not, any other suggestions?:thumbs
patrickc
Ontario, Canada
The weight rating on those tires is fine for your truck but I think they will be to big even with the leveling kit. A 325/60R20 tire is 35.4" tall and has a tread/sidewall width of 12.8". I would downsize to a tire that is 35" or smaller to be sure you have enough clearance. A 34-34.5" tall tire would probably be the perfect size and give you lots of clearance.
jonlorio
well i originally was looking at the 325/60 bc from the factory, my truck came with 275/65/20's which is a 34" tall tire. i would like a slightly larger tire(both tall and wide), and there aren't many options for me to choose from for a 20" wheel.
anyone have some suggestions? what's some common sizes/tires ppl are running on the factory 20" wheels? i've searched and searched but all i can find are ppl's setups for the ford 18" wheels...
