Speedometer & Trans problem
action4478
Muskegon Mi
I found this site very helpful with a couple issues I had with my 97 ps 350. Thanks to all for the time you spend entering your experiences. The last problem was a speed sensor issue. Speedometer bouncing back to 0 mph & the trans would also act up. Turned out to be a bad spot in the wire leading from the vss. Reading the forums helped me figure it out Thanks, Rick
Wood County Tx
wooooo a new guy and he found good info here to fix his truck
cant get much better than this :sweet :sweet
welcome aboard
glad you found us
94f450sd
certified nutjob
plymouth,ma
good to know that our problems and answers have helped somebody.welcometo the site :sweet
Welcome Rick, glad that some of our useless dribble actually turned out to help you.
clem
N.E.Ohio
Rick, you will be able to help someone out now,Welcome.
action4478
Muskegon Mi
trans & speedometer
Thanks again. I just bought this 2 weeks ago & I was only able to drive it 4 days out of 14. First it was no fuel pressure then it was the trans not shifting properly. The fuel problem was the fuel pres reg & the trans was the wires from the vss. Kind of a pain. Keep up the good work. Rick.
