steering shimmy when braking
bonfire
Richardson, TX
On a recent trip to Arkansas, noticed this problem with the wife's rig. First thought was warped brake rotors but I dont feel an oscillation in the brake pedal. It's definitely coming through the steering wheel and only does it during braking? Any ideas. I refuse to let Ford fix it for what will undoubtedly be $400.00.
Bill
Bill,are you on the original brake pads/rotors? If so how many miles on em or how many miles since they we're last serviced?
Whats the tires conditions/mileage?
bonfire
Richardson, TX
As far as I know they are original. Close to 70K on the meter. Tires are relatively new. We did the Pirelli Scorpion's thing during the recall
Mark Craig
Advertising Sponsor
Franklin, Tn
bonfire,
99% of the time that's warped rotors, some guys have found that ball joints can cause it too though.
Mark @ DPPI
Got Diesel
Engineering College Boy
Missouri
I bet it's the rotors. I had the same thing in the truck. Didn't feel it through the brake pedal either. Just a thought, you could at least get them turned, cost about 10 or 15 bucks usually.
bonfire
Richardson, TX
Guess its like taking a multiple choise exam. If your not 100% sure of the answer always stick with your first guess. Thanks a bunch guys.:thanks
Bill
dzl_x_4x4
Dzl_X_4x4
Rowlett, Texas
I can think of several things, also.
1. Rotor.
2. bad tire/balance or tire not seated right when installed/torqued and/or loose lugnut(s).
3. Steering Damper.
4. wheel bearings.
I had my wife "break" the end link off of my Hellwig swaybar last month, Yes I said broke compltely off. I don't know if it was a tire out of balance or the swaybar end link. But after balancing the tires a 2nd time in a week and fixing the end link (we missed it during the first tire balance/rotation) problem gone.
Good Luck! I say go cheap (re-balance and rotate the tires) and see if it changes or moves the problem to the rear.
