Sticking passenger door lock
HCAbowman
Fayetteville, NC
Well, 112K on the X and the back door lock wont go up and down with the power locks, but you can do it manually, just havent had time to take the door panel off to see whats going on in there, Im thinkin just some lube, but if yall have any suggestions that might be the culprit, I will be greatful!
:thanks
Digital Oxygen
Got Boost?
Rockies
Well, if it doesnt lock/unlock with the power lock button, then it sounds like your door lock actuator on that door is kaput.
Same thing I was going to say before reading DA's reply is the actuator. I had the back panel off tightening down a couple exterior bezel bolts and could observe the actuator in there. Doesn't look like a tough task to replace:sweet
