Stock Fuel Pump Good To What Injectors?
dboyw
Lancaster, PA
As title says. What will the stock fuel pump handle in injectors. Have a few years till I can upgrade injectors, but fuel pump may be comming sooner. Truck will be a daily driver with hot rodding now and then. Towing a fifth wheel hopefully once a month.
Thanks
I think I'd do a Swamps IDM and get all you can out of the stockers before you coin out for squirts and a pump..plus, you're going to want to upgrade both the fuel AND oil pumps anyway..
94f450sd
certified nutjob
plymouth,ma
Would not trust swamps to mess with an idm.burnt trucks come to mind anytime i hear thier name.
Stock electric pump will support somewhere around 1,000hp.will be more than enough for what you plan on doing with your truck.its everything after the pump that you want to upgrade.
rhensonsr
