Tire question
Jim up north
Lachute Canada
I have 4 brand new 245/16 E load range tires and rims from my old truck a dodge 2500 diesel. The ford has 265's , can I use at least the 245s on my F-350. Or do I have to have the transmission reprogrammed or something to accept these tires?:thanks
Jim
You should be able to run the 245's without any re-programming. They are close enough in size.
I wouldn't...
I mean, you could if you HAD to, but the 245, beside being almost a full inch shorter than the 265 (affecting the speedomoeter), also lacks the capability to carry as much load as the 265...
Digital Oxygen
Got Boost?
Rockies
What's the exact tire size? xxx/xx/xx
Go here, plug in your oem size, and the new tire size. Then, by the magic of Java Technology, the calculator will give you a nice graphical representation of what your tire size difference is, as well as revolutions per mile, speedometer offset, the works.
http://www.miata.net/garage/tirecalc.html
I know, the link is to a Mazda Miata site, but you'll just have to grin and bear it, and don't tell anyone you used it. :lol:
