Tire Size Guru and MPG
Ken1
Mississippi
My F350 CC 4X4 W/4:10’s came from factory with 245/75R/17/E tires. Could I change to a 265/75R/17/E and improve fuel mileage. With the tire size change what would be my adjusted gear ratio? With this small ratio change I would expect some improvement in MPG. I also understand I would need to have speedometer adjusted to new tire size.
Maxtor
Redding
245/75r17 tire is 31.46 inches diameter
265/75r17 tire is 32.64 inches diameter
You would have to have 36 inch tires to get the same rpm as a stock truck with 3.73 gears.
The heavier tire would lose some of the mpg gain.
stock 2006 psd 18 inch tire is 275/70r18 equals 33.15 inches diameter.
If your goal is to increase fuel mileage, you might consider going to a 3.73 differential.
fyi
5 spd auto over drive ratio with 4.10 gears is 2.911
5 spd auto over drive ratio with 3.73 gears is 2.64
manual over drive ratio with 3.73 is 2.68
Ken1
Mississippi
My goad is to improve MPG but at the same time not to limit towing. I was only think in another 18 months I will need to replace tires so with a tire change due could I pick up some MPG. The gear change would limit towing but also would be costly. If diesel stay above $4.00 we all could be looking for 3:08 ~ 3:73's
Thanks
