Tail_Gunner
CRJ & ERJ A&P Mech.
Is there a common sized, narrow profile tire (highway/ better mpg) similar to a 235/85R16 but slighty taller in diameter?
common sized, narrow profile tire?
Nope, there's not a good option, and really you likely wouldn't want any taller tire without some more width. As your tire is taller, cornering is affected, and you wouldn't like the sponge feel that you'd get.
Either way there's not a common sized tire out there by anyone that will be taller without also going wider.
Keeping one thing in mind, different manufacturers use different bases to size there tires, and one manufacturers LT235/85R16 is not the same size/height as all the others. typically you won't find much over a 1/2" height difference though.
LT235/85R16 E 10 PR
Michelin LTX MS is 32" tall
BFG Mud terrain is 32" tall
Goodyear G614 RST is 30.7" tall
WOW 1.3" difference here, but I believe tread depth may be a portion of this (but shouldn't be).
I have LT295/75R16's on my '04 250 CC with just over 33" height, but fairly wide and mileage went down a hair.
GOOD LUCK.
LT235/85R16 E 10 PR
GOOD LUCK.
