Tony Wildman's 4 pos chip & DI Intercooler
White Buffalo
TDP Pit crew
Fort Sill, Oklahoma
Well, Just thought I would post the results after adding Tony Wildman's (Totaldieselperformance.com) updated Tow programs and the Diesel Innovations Intercooler (http://www.dieselinnovations.com/di.php?page=products&cat=1). What a huge difference on power & EGT's! My camper is a 31" Outback 5th wheel (approx 9,500 after fully loaded) The OAT was 92 degrees. I have two of Tony's tow programs on my 4 position chip. One is @ +40hp and the other is @ +80 HP. I basically got one for towing on the flats and one for the hills. Both programs have the shift point to OD set at 55 MPH. This feature is great, no more lugging at 45 MPH if I forgot to hit the OD off button.
Towing at:
70 MPH = 800*
75 MPH = 850*
80 MPH = 900*
This was while driving on relatively flat terrain. Even while climbing uphill in the +40HP tow program I never went above 1150. When I used the higher HP tow program I would get 1250+ climbing hills, but I mostly used this on the flats, for the added passing power or to get up to speed entering the Interstate. Worked great. Overall I guess a saw a 200* drop in EGT's while towing because of the DIIC. Also need to thank Jon Faubion the the Van Turbo install.
Race22
Jim
Moore Okla
Thats cool. What is amazing is how Tony's chip wakes up your truck. I have the econo, tow, extreme burns. I tow my 12K fifth wheel in the econo mode most of the time. Boost doesn't go over 22 lbs but when I need the power, I switch to the tow mode. Egt's go to about 1250 but boy does it pull.
dserge66
