Tool descriptions
Fire1
Certified Diesel Driver
DRILL PRESS: A tall upright machine useful for suddenly snatching flat
metal bar stock out of your hands so that it smacks you in the chest and
flings your beer across the room, splattering it against that freshly
painted airplane part you were drying.
WIRE WHEEL: Cleans paint off bolts and then throws them somewhere under
the workbench with the speed of light. Also removes fingerprint whorls
and hard-earned guitar calluses in about the time it takes you to say,
"Ouch...."
ELECTRIC HAND DRILL: Normally used for spinning pop rivets in their
holes until you die of old age.
PLIERS: Used to round off bolt heads.
HACKSAW: One of a family of cutting tools built on the Ouija board
principle. It transforms human energy into a crooked, unpredictable
motion, and the more you attempt to influence its course, the more
dismal your future becomes.
VISE-GRIPS: Used to round off bolt heads. If nothing else is available,
they can also be used to transfer intense welding heat to the palm of
your hand.
OXYACETYLENE TORCH: Used almost entirely for lighting various flammable
objects in your shop on fire. Also handy for igniting the grease inside
the wheel hub you want the bearing race out of.
WHITWORTH SOCKETS: Once used for working on older British cars and
motorcycles, they are now used mainly for impersonating that 9/16 or
1/2 socket you've been searching for the last 15 minutes.
HYDRAULIC FLOOR JACK: Used for lowering an automobile to the ground
after you have installed your new brake shoes, trapping the jack
handle firmly under the bumper.
EIGHT-FOOT LONG DOUGLAS FIR 2X4: Used for levering an automobile upward
off a hydraulic jack handle.
TWEEZERS: A tool for removing wood splinters.
PHONE: Tool for calling your neighbor to see if he has another
hydraulic floor jack.
SNAP-ON GASKET SCRAPER: Theoretically useful as a sandwich tool for
spreading mayonnaise; used mainly for getting dog**** off your boot.
E-Z OUT BOLT AND STUD EXTRACTOR: A tool ten times harder than any known
drill bit that snaps off in bolt holes you couldn't use anyway.
TWO-TON ENGINE HOIST: A tool for testing the tensile strength on
everything you forgot to disconnect.
CRAFTSMAN 1/2 x 16-INCH SCREWDRIVER: A large prybar that inexplicably
has an accurately machined screwdriver tip on the end opposite the
handle.
AVIATION METAL SNIPS: See hacksaw.
TROUBLE LIGHT: The home mechanic's own tanning booth. Sometimes called a
drop light, it is a good source of vitamin D, "the sunshine vitamin,"
which is not otherwise found under cars at night. Health benefits aside,
it's main purpose is to consume 40-watt light bulbs at about the same
rate that 105-mm howitzer shells might be used during, say, the first
few hours of the Battle of the Bulge. More often dark than light, its
name is somewhat misleading.
PHILLIPS SCREWDRIVER: Normally used to stab the lids of old-style
paper-and-tin oil cans and splash oil on your shirt; but can also be
used, as the name implies, to strip out Phillips screw heads.
AIR COMPRESSOR: A machine that takes energy produced in a coal-burning
power plant 200 miles away and transforms it into compressed air that
travels by hose to a Chicago Pneumatic impact wrench that grips rusty
bolts last over tightened 50 years ago by someone at Ford, and neatly
rounds off their heads.
PRY BAR: A tool used to crumple the metal surrounding that clip or
bracket you needed to remove in order to replace a 50 cent part.
HOSE CUTTER: A tool used to cut hoses too short.
HAMMER: Originally employed as a weapon of war, the hammer nowadays is
used as a kind of divining rod to locate the most expensive parts not
far from the object we are trying to hit.
MECHANIC'S KNIFE: Used to open and slice through the contents of
cardboard cartons delivered to your front door; works particularly well
on contents such as seats, vinyl records, liquids in plastic bottles,
collector magazines, refund checks, and rubber or plastic parts.
DAMMIT TOOL: Any handy tool that you grab and throw across the garage
While yelling "DAMMIT" at the top of your lungs. It is also the next
tool that you will need.
EXPLETIVE: A balm, usually applied verbally in hindsight, which somehow
eases those pains and indignities following our every deficiency in
foresight.
:roflmao :roflmao :thumbs
You Got it MAN:roflmao :roflmao :roflmao :roflmao :roflmao :roflmao
One more...
JESUS NUT: A nut or bolt commonly used to hold a vital part or assembly inplace. Makes you think:
JESUS, I hope this thing never comes loose... as you are applying a torque spec or
center something for a Cotter pin.
Wood County Tx
in Kaman H-2 days we had a nut we had to torque until it STRETCHED.
the whole gauge and socket fit toghether on teh rotor head while you pullled it to around 250 or so foot lbs.
very often it would pop off just as you applied the required turning forces,
geuss what you said as you went flying??? JESUS:roflmao :roflmao
it aslo became our :jesus nut"
I hear Ya. I picked that up from an H-1N mech when he was installing a new rotor head assembly. Got to think'n 'bout it..... There are ALOT of Jesus nuts'n bolts when you Turn Wrenches ... On just about anything.
Rookie
Maple Valley Washington
Way too funny.
This reminds me of an anger management (long story) session I had. One of questons I was asked was about throwing things when I got mad. I said "Yeah it makes me feel better". After a couple of weeks I was if I was still throwing tools when I got mad, "Nope, now I just throw them on the ground in front of me cause there're easier to find..."
Jesus clips; the ring shaped metal pieces that fly off when you don't want them to fly off, causing you to say :Oh Jesus where did that go?". Never to be found again in this century.
whatabudro
Launched
LIQUID WRENCH: when all has failed, take a moment to use the liquid wrench. Open your favorite adult beverage, and before you finish it, an idea will come to mind. Most of the time leading to the roll of electrical tape to stop the bleeding. :cool:
HCAbowman
Fayetteville, NC
Amen to that...we have "helen keller" bolts in the leading edges on our C-130's, what a pain in the azz...
Great descripitions there Fire!! Thank ya!
Tbar
SDD STAFF/Moderator
Lessee.....................
I have almost done a self vasectomy when a 3/8" hand drill with a 3/4" spade bit slipped.
I have almost set myself on fire with the oxy/act torch but have successfully used one to start damp charcoal......
Used a ten foot long 4x4 to lever my trailer tires back onto the narrow bridge they had fallen off of.
Used a 16" long flat head screw driver to test continuity between a 440 buss bar and the back of the enclosure it was in. Saw stars for hours.
Have danced on a narrow beam 14 feet in the air as a hot welding slag found it's way to mister happy.
Have sat down on top of a bare light bulb searing a nice circle onto my bare inner thigh.
Tbar
