If changing oil types aka syn or dino different weights maybe etc makes since, I did it when I swapped injectors and when I went to synthetic, but provided you maintain your oil changes like you should, the left over oil will be black as coal for sure, but it should have minimal effect on the oil after the change. Like said probably more like 2 qts total top end, not a huge percentage when you think how much ours hold...
