Transmission fluid flush pays
With the recent repairs I've done to the truck this week I also changed the 4R100 filter and did a flush of the old transmission fluid.
All I can say is wow! what a difference new fluid and a filter makes even after only 31k on the old fluid:sweet
I installed the sonnax and tricumulator kit during the original trans filter/fluid change a few years back.
JRJ04
Houston, TX
so does that mean you're rethinkin the bts?
good for you ! as they say an ounce of prevention is
worth of POUND of cure !
We hit 31k and decided to do the filter and fluid flush.We have a few months till BTS and sticking with the plan but in the event we can't make it up in June the transmission will operate well thru then:)
Fluid and filter is cheap problem prevention;tu
platinum01
Willis, TX
How long did it take you to do all this? How many quarts did you use? What kind of fluid are you running. Truck has 132k on it and getting ready to start putting alot of highway miles on it and I know that it is getting time to do a change.
platinum01
Willis, TX
Do you happen to know what trans I would have in my truck. Is the amount of fluid any different. I don't mind doing the work myself just want to make sure all is right and I know that I can trust ya'll when it comes to this.
7.3L automatics were equip'd w/ the 4r100 (you can you fluid other
than mercon SP)
Less than 2 hours;
Drain old fluid
Drop pan,clean pan and magnet
Install new filter(less than $20)
Reinstall pan(with reusable factory steel core gasket)
Proceed with flush procedure and top off till in the crosshatch mark.
Trans fluid Dexron III/Mercon $18 plus tax for a case of 12 quarts at Sam's,you'll need almost 20 quarts for the entire flush including top off.
The extra fluid I'd use to flush the power steering system and bleed the brakes with new fluid.
If you were in the area I'd gladly help with the work just like anyone else:sweet
platinum01
Willis, TX
I am in Kansas right now but heading home tomorrow. Taking of Thrusday, Friday so may do the service those days. Thanks for the heads up. How often do ya'll change your tranny fluid?
DesertDuty
So. Cal
Hi guys,
With the transmisson flush is anyone using the new mercon V in a 4R100.
I know that Ford reformulated the mercon V to work in the 4R100 but, I was wondering how it is working.
Desert Duty
