TS Chip
Dieselmech
Thats what ill try. I tried reading the link but it wasn't able to load. Dont know whats wrong with it. Anyways, thanks again for the help.
Dieselmech
Thanks for the link. So, yo think if I pull the IPR and clean it up, it will fix the problem? I sure hope so, alot better than replacing the pcm
action4478
Muskegon Mi
If the soloniod on the IPR is working, Then the IPR valve is probably stuck. If you want to remove that variable, get a new one. I see them on E Bay for cheap.70 -100 dollars sometimes.....
Dieselmech
Found a couple on ebay, cheapest one was 150. Not for sure if the solenoid is working or not, haven't really had a chance to look at it to hard. Still haven't even towed it home. Was it the IPR that was giving your truck problems?
action4478
Muskegon Mi
YEP....
X2 CHECK IPR COIL RESISTANCE
Measure resistance of IPR coil.
Is resistance 5 to 20 ohms?
If not replace it
