Question Tuners and Gauge pods
Fummins6
mn
MY truck has a banks chip in it now and i was looking at changing it to Dp tuner. so any information on the dp tuner good or bad
has anyone seen a pillar pod that holds 5 gauges and if so who makes it
coondog491
McAllen,TX
I've only seen 4 max.
I'm pretty sure thats the biggest you could get.
you could try getting a 4 gauge pillar and a overhead console pod, they have some that hold 1,2, and 3.
Dieselmanor.com has a good selection, plus a good deal on ISSPRO gauges
aaklingler
Winfield, PA
I've heard some stuff about trucks running Dp Tuner blowing up because of to advanced fuel timing.
Unless you like lots of Gauges....... ?
I have a 4 gauge, "A" pillar pod.. EGT, Boost, Fuel Pressure and Engine Temp.. By installing a micro switch next to the Engine Temp gauge.. on the Pod.. Up is Engine temp, Down is Trans Temp. (or, in yer case.. oil temp ;))
By installing another micro switch (down on my dash).. Up is the Trans temp, Down is Dif temp.
6 readings from 4 gauges.... Or... 5 readings from 4 gauges.. Sans.. the second switch. :dunno
