turbo
DSR
USA
just installed beans stage 2 and tuner today have after cooler not installed yet ,what should i be looking to by for a turbo. 1996f250.
tubzz
st.clair mo.
H2E all the way:sweet ,
what kind of programmer is it?a chip would blow the programmer away
94f450sd
certified nutjob
plymouth,ma
get that intercooler installed before you go playing with your new injectors!!!alot of guys are running an H2E on thier trucks.beans workin on a drop in hybrid turbo,dont know if its finished yet.there are some kits to install an H2E on our trucks but theyre expensive.
94f450sd
certified nutjob
plymouth,ma
what he said about the chip.now you do also have a pyro and boost gauge installed right?
DSR
USA
chip
its an has 3 settings ecno. tow and wild i got it from beans with injecters . running with out after cooler egts can get to have at much over normally driveing. left bd chip in for short drive great power but hard to keep temp down.put 3 setting one in, way more driveable but not as smooth at idle?
94f450sd
certified nutjob
plymouth,ma
if your running the extreme setting all the time the idle is gonna suck.how bad depends on wich extreme you have.
96EDGEpsd
Welding/Fabrication
New York
this is a little off the subject, but is there a big difference between wildman burning and regular TS...??
94f450sd
certified nutjob
plymouth,ma
do we need to answer that?but i will OH YA!!! :burnit :burnit :sweet
