Up Pipes Gasket
Got Diesel
Engineering College Boy
Missouri
My up-pipes have leaks where they meet the pedistal. I was just wondering what the best way to change these out our. I know the gaskets don't cost that much, but I wasn't sure if you had to drop the tranny, or if you pulled the turbo off. Thanks for the help.
BBBxcursion
IL
Just undo them from the back of the turbo, then the manifold, and slide 'em out :)
roosterdiesel
Earl needs B100
Amarillo,TX
Sometimes the pipes get holes worn in them. When you change them look them over real good where the donuts go. ALso small block chevy donuts are a little thicker and used by many. I recommend alot of PB blaster on the bolts so they don't break and cause more headaches.
