Upfitter Switches
Dean Soderberg
GA
I have a 2017 and am trying to connect to the dead ended upfitter switches. The owners manual says they are located under the panel on the passengers side kick panel. I found no wires dead ended that match any color scheme in the book. Has anyone connected to the 2017 Upfitter switches yet?
Don't know about a 2017, but on my 06 (and that was a long time ago),
I had to pull the glove box to find them. Hope this helps and Welcome
to SDD.com. Tell us about your new truck and post up a picture or two of it.
Dean Soderberg
GA
Thank you very much, we had an 08 and they moved the wires to the driver side, guess to many people complained. I will take a look. Thank you again. I will post a pic or two 2017 F-250 Platinum, Magnetic color with the 4x4 package
FWIW ? My 012 [Dead Ends] were On the D side. The Fuses are on the P side. Mine were taped to a main loom.. in the upper D side, above and forward of the E-brake assembly. They all had Black "Dipped" ends, and a color code/legend tag... once I found them.
Again FWIW ? I cut the legend off, and stuck it in the 6.7 Diesel Supplement Book.. so I didn't have to be Upside down/Backwards to read it.. for future hook ups.
On Edit: I've done a Bunch of Upfitter switch wiring stuff. If I can be of any help on DYI add-ons.. Post it up or PM me ?
Dean Soderberg
GA
Not there, i will go to the Ford Dealer and have them find the wires........
Thanks
jimbob394
Winter Park
Thanks
Hey here's a video I made where I connected a couple of lights to the upfitter switches in a 2017 F-350. Hope this helps!
Dean Soderberg
GA
Founds the dead ended wires in the engine compartment drivers side under the fuse box. Tha nm k you too everyone for the inputs
F350 On Track
