Question Vacuum problem or A/C
shhorn68
Haworth, OK
I know I have a vacuum problem since my A/C blows out my defrost vents when I first turn it on. However, my A/C does not cool as well as it should and I was wondering if the two problems are connected or if I just need to charge my A/C and fix my vaccum leak. Sorry I cannot give any more details but I noticed the problem a couple of weeks ago and have been gone on a job since then.
Sounds like you have two problems, vacuum and low freon. The vacuum leaks are generally near the hubs, where vacuum locks/unlocks the hubs. Look for a vacuum line at the wheel assy.
shhorn68
Haworth, OK
That is what I was wanting to hear. Well, not really what I was wanting to hear but I was hoping the two problems were not tied together. First chance I get I will check the hubs and freon level to determine what needs to be done.
Thanks.
sagebel
Stock? Pfft!
Albuquerque, NM
Also check up under the glove box. There is a vacume connector there that can get disconnected by the passenger's feet.
So this is what you get for carring around those big footed women,with sharp toed shoes. LOL:tounge
sagebel
Stock? Pfft!
Albuquerque, NM
Or the one that like to wedge her flip flops under the dash so she can put her feet up. This was after I scolded her for getting the dash dirty.
shhorn68
Haworth, OK
I appreciate the input. I still have not been around my truck to check it out. My father-in-law has borrowed it, to move hay equipment, and he added some freon to it. He said that it cools much better now. Maybe the next time I am home I will get a chance to check out the vacuum leak.
jccapri
garland,tx
new here hello just got a 2001 F350 4x4 crew cab SD the ac is blowing out the defrost vent i know if i look and look i will find the anwser but if someone can help thanks
:welcome2 jccapri. Glad you joined up. Air going through the defrosters is a vacuum problem. Check your vacuum pump and reservoir.
Dave :)
jccapri
garland,tx
fixed
will i know what it is it is the valve that is under the hood on the right side it has 2 vaccum lines and a wiring plug undo the vac hoses and stop up the red one and the vents will start working . IT IS CALLED A PULSE VACUUM HUB LOCK SOLENOID it goes bad when the lines on the axle hub has a hole and dirt gits sucked in to the solenoid.
dserge66
