Want to lift the dually, but...
patrickc
Ontario, Canada
I am planning to lift my dually in the spring. I have my heart set on a 6" lift with 35's. I plan on running 35x12.5R17 Mickey Thompson mtz's on the stock rims.
My question is...Will I need a 2" spacer for duals or should I go with a 3" spacer just to be safe? How much space is needed between the tires? 1/4"? 1/2"?
I am also concerned about the front tires/rims clearance. Will there will be enough clearance from the suspension components while turning? Will I have to run spacers up front too?
I have lifted lots of single tire trucks but this will be my first dually so I am a little unsure. Any input is appreciated.
Thanks, Patrick.
