water in fuel light on
06superdutyfx4
Atlanta/Ga
My light came on water in fuel,I have drained the water /fuel seperator 3 times and haven't seen any water?????Can i add an additive or what is the best advice?
ralphinnj
Lifted Dually in NJ
North central NJ
sensor might be bad? Should not get set off right after emptying th decantor. And since you see no water, it must be a bad sensor. I don't think it picks up on the water that might be in your fuel (low levels) unless it is a defective sensor.
Ralph
waford250d
tacoma Wa
sensor
mine just did the same dealer said terminals on sensor bad they replaced sensor its all good now
