Well... I took the plunge
I noticed the running board too. I know that the few times mine has been on a lift, the lift arm rest right under the running board and it will bend them.
Digital Oxygen
Got Boost?
Rockies
The running board does seem to sit a bit higher, but it doesn't bother me much. Looked under the truck in that area for visible damage, didn't see any.
Truck runs great. I had the fuel filters and oil changed in Birmingham 'bama, now it's sitting in the service dept. at a FORD dealer in Phoenix where I had an alignment done, it's gotten the coolant T recall installed, passenger seat heater pad ordered, and the radiator is in the process of being replaced. I had read up about the radiator and had them make sure it wasn't leaking... it was in the process of starting to leak.
Other than that OASIS shows no previous warranty work on the truck. I don't know if that's a good thing or a bad thing what with it having 30K miles.
dserge66
