What Are These................???
Tbar
SDD STAFF/Moderator
Saw these behind a Superduty in my neighborhood a few days ago and wondered what they were...........???
Tbar
They look life gold cart versions of some Hummers.
That is too much trailer for that truck. Is the truck a 250 or a 350?
Wedges were meant to be pulled by a dually.
golf carts
Honestly I have no problem with the wedge for towing golf carts, I grew up in a town full of golf carts and they are not that heavy even a SRW 250 will not have problems towing that trailer full of carts, I can't tell from the angle but I have seen trailers that are narrower and designed just for golf carts, then again I have seen them modified so that they load up two rows of carts on the trailer also.
If golf carts are all he hauls, then it would probably be OK, but look at the squat that trailer
is putting on the tail end of the truck. The golf carts can't weight much, compared to a car.
I am willing to bet that he hauls regular cars and trucks too. I doubt very seriously that he is always loaded coming and going with just golf carts.
You put a couple of cars and pickup on that trailer, and the he is putting some major weight over the axle on a F250.
Our trucks are tough, but that is TOO much trailer for a 3/4 or even a 1 ton SRW truck.
The manuf. of that trailer is Kaufman and they do make a golf cart wedge trailer, but is not as heavy as
one made to haul cars. Instead of 2 ramps (one on each side for cars) the deck is a solid metal mesh design.
You can haul golf carts 2 wide all the way up the trailer.
those suckers are bigger than they appear
DIMENSIONS & WEIGHT
* LxWxH: 152.5" x 58.5" x 72" (387.5 x 148.6 x 182.9 cm)
* Wheel Base: 103" (261.6 cm)
* Cargo Deck Area (usable space L x W):
* 27" x 55" (68.6 x 139.7cm)
* Cargo Box (from ground): 34" (86.4 cm)
* Weight With Batteries: 1850 lbs (803kg)
They are a small car so I retract my previous statement about not being overloaded, should have known that the car hauler would have been right :notworthy
