What is the sensor on the lower drivers side of fuel filter housing?
schreckman
Schreck The Tech
Brighton COlorado
Have a sensor or something connected on the lower driver side of fuel filter housing on a 2002 7.3. It's not hooked up and the wires have been tied off. Curious what it is and why someone would disconnect it.
Tail_Gunner
CRJ & ERJ A&P Mech.
Da U.P.
Sounds like the fuel bowl heater element. Sometimes these things will short out, blowing a fuse. That same fuse provides power to the PCM. So if the heater element shorts out, blowing the fuse, the truck won't start/run. Removing the wire connector and replaciing that fuse is a quick fix to get the truck running again. Sounds like a previous owner didn't get around or bother fixing the heater element.
