Question Whats the deferents
Dogman
tampa,FL
Whats the deferents between the H&S XRT PRO TUNER and the H&S MINI MAXX TUNER other then 300 bucks? I'm looking for one with the DPF/EGR delete.
Thanks Russ
superduty6.4
alberta
Thanks Russ
The xrt does not have gauges and I don't think it has shift on the fly capabilities. I could be wrong about the shift on the fly part. I was in the same boat and went with the mini and am very pleased with my decision. The unit is small but I have no problems seein the gauges.
superduty6.4
alberta
Both the xrt and mini disable the EGR on the mild and hd300 tunes. The easy tunes function the EGR at an idle I believe.
Dogman
tampa,FL
Thanks, The mini max uses the oem exhaust probes for the EGT, Right?
superduty6.4
alberta
Mini maxx
Yes it uses the one before the turbo. If you install the mini and dpf delete tune the probes on the exhaust after the turbo are not needed anymore.
