Wheel bearings???? questions
Lifted_Stroker
Cummins eater
waynesfield,ohio
My front right is starting to go south, so im gonna tear into it some time this week. my question is how much cash am I looking at for all 4 of them? I tried to find them on power stroke shop, but I cant find them and Im sure they have them. does any one have the part number? i would greatly appreciate it. Lance
You are in for a big surprise. There are no individual wheel bearings. They are a factory subassembly that contains the bearings and the hub as one unit. And they are in the $300 - $400 range.
Sorry, Dave
Hooper
Hemet, Calif.
The studs that attach the bearing to the truck can be very difficult to remove. I would seriously consider buying new studs from Ford and make sure you have a new o-ring seal as well.
mech2161
Morgantown WV
If your truck does not have ABS you can still use those hubs and cut the wire of or zip tie it out of the way. They are cheaper.
