When putting a car on a dolly.......
Silver_Crew
NW Louisiana
Should it be in Park or Neutral? The car is a Pontiac Sunfire, front wheel drive with AT. Front wheels will be strapped down to the dolly. Trip will be almost all highway miles, about 900 of 'em.:eek:
Thanks, Greg
And make sure you stop every two hours or 100 miles to check everything out and retighten the straps.
Russ
Found On Russ' Drive
New Brighton PA
Does the dolly have pivot points under the car tires? If not then the steering wheel needs be unlocked in the car so the wheels can turn(left-right). Car should still be in park but, steering column unlocked. If the dolly has pivots drive on, put in park, take your keys, and strap it down.
