Help Needed wipers
moomrack
vancouver bc
Hi every one
So my truck is a 2003 F350 XLT Larriett shrort box with a 7.3 l
dp tuner 4" exhaust leviling kit
now what the problem is my wipers stoped working i re &re the motor they worked for 3 weeks and now stoped agian my sprayers dont work aswell but before they did all fuses are good :dunno
Smoky
Mississippi State
Check for power to the wiper and spray pump motor. Make sure the contact are clean and tight.
BTW.....:SDD
check the relays in the PDC under the hood.
might have been the problem to begin with..
Tail_Gunner
CRJ & ERJ A&P Mech.
Da U.P.
Check the wire harness connector that plugs into the turn signal lever/ wiper control module.
Mine had the locking tabs on the connector broken off and the connector plug was backing out of the turn signal lever/ wiper control module, making only partial & intermittant contact.
I was having turn signal problems. But wiper control circuits go through the same harness plug, so its a possibility.
I posted a decent photo article on how to get into the steering column there at the turn signal lever/ wiper control module that was supposed to get put into the WIIKI, but it never happened. :dunno
Kent..
find that thread & subscribe to it..
then you can link it back when you need to
Tail_Gunner
CRJ & ERJ A&P Mech.
Da U.P.
Here's the turn signal mod I did a while back
TURN SIGNAL MOD
But it doesn't have the broken cable plug I had to fix. I gotta look some more.
