Wtf??
Glassdude
Sonoma, CA
Strange things are happening. Here's what happened. Backing in to a friends carport the idle started to get rough and had tons of white smoke. Got out of the truck and could smell raw fuel and it was bad. I'm thinking I've got a bad injector. Only 265,000 on the original injectors. It sat for a couple hours and I decided to try to get it home. Started and idled rough and had white smoke for a bit then evened out. The trip home it didn't miss a beat. Next morning I did a buzz test. All sounded good. Did a CCT and failed on #8 as always. No codes. IPR duty cycle and oil pressure look normal. I've driven about 75 miles since all this with no problems. :dunno Only thing that I found was oil level was low (about 3 qts) I changed the oil and fuel filter. Anyone have any explanation or what else I need to check?
RSG
Savoy IL
water in the fuel, but you cured that with the filter change?
