2 dtc codes won't go away
hetner1102
Austintown, Ohio
I have an F250 2008 6.4L. K
I have done a few mods, S & B cold air intake, H & S Mini Maxx Tuner, DPF/CAT Delete with 5 inch straight pipe Magnaflow exhaust. The 2 codes I keep getting are ----P006B-- MapSensor, and P2563 Turbo Boost Control Position Sensor Range/Performance.
I had it at ford they say that with all the stuff off (DPF AND CAT), and with having the Cold Air Intake the motor has no idea what it's doing. They recommended me putting back to stock. I pull a 40 FT Fifth wheel and stock is not an option.
I did replace the EBP Sensor and cleared codes was good for about 100 miles then same thing.
I called H & S they said the 6.4L fords don't like the cold air intakes and if I went back to stock air cleaner assembly the problem would go away.
There has to be a ton of trucks just like mine running out there with the same mods, are they having issues as well? I have a hard time believing that I spent all this money just to be told the 6.4 don't like it. I have an air dog yet to install, but I can't get rid of these issues before throwing something else in the mix.......
Does anyone have any idea where to go next ? Any help would be appreciated from everyone. Dumb question but I have to ask, my 5 inch Magnaflow is a straight pipe, I did just order a new exhaust from MBRP, COOL DUALS there called. Can this be as simple as I need a muffler that's why it doesn recognize any back pressure. How is everyone else running similar setups like mine getting away with it ? My new MBRP wont have a muffler either.....Suggestions from anyone ? Thank You in advance...
pubs34
puyallup wa
You can see what i got for a set up, even had the charge pipe rebuilt, mine is getting more air than stock,a lot more air, AFe intake and 4" straight back exhaust, had it on since march of this year and have had no issues or codes being thrown. Not sure what yours is up to or why.....
Ratheon
Hampton, VA
I find it odd that H&S says the 6.4 doesn't like a cold air intake. Especially since nearly every modded 6.4 out there has this upgrade. I have had no codes since installing mine. I have mostly run KEM tunes though. I wish I could help a bit more with your delima and will ask around at work tomorrow. It doesn't suprise me that the stealership will blame the mods...if your windshield wipers were leaving streaks they would blame it on the tuner, at least that's how it is out here in eastern VA.
hetner1102
Austintown, Ohio
I can't figure it out either, H and S has been very helpful, had me try a lot of things, even told me to put 2-300 miles on it it should reset. They said it may be learning my driving. It's been on since September and no different. I totally disagree with what they say, but whats next? Like I stated, there are a million trucks like mine out there, what's the difference ?
Thanks for your time.
hetner1102
Austintown, Ohio
Your right, the ford dealers are no help at all. I just know that when I have no codes, the truck runs fantastic, with the codes its horrible. Major turbo lag, throttle response sucks, it almost seems as if it's getting too much fuel, for instance around 30 MPH, if you hit the pedal it takes a while to clear itself out, for boost to come in, it takes around three quarter throttle, then when boost hits around 20, and the black smoke clears it's fine. H & S did tell me to get rid of the CAI, I haven't, I did clean the MAP sensor, and replace the EBP sensor ran great for 100 miles then right back where it started from. I guess I am just confused. I have a Vortech blown 91 Mustang and never had that throw any codes. I just don't like the fact everyone is blaming someone else, and I'm stuck with something that dont run correctly.
Thank you for your time.
I can't figure it out either, H and S has been very helpful, had me try a lot of things, even told me to put 2-300 miles on it it should reset. [They said it may be learning my driving.] It's been on since September and no different. I totally disagree with what they say, but whats next? Like I stated, there are a million trucks like mine out there, what's the difference ?
I Really think there's something to that.. "Adaptive Learning" thing. My 2K runs Stronger, after a good Road Trip, with the 5r in tow. Then it seems to go back into a Daily Driver mode. :dunno
[Your right, the ford dealers are no help at all.] I just know that when I have no codes, the truck runs fantastic, with the codes its horrible. Major turbo lag, throttle response sucks, it almost seems as if it's getting too much fuel, for instance around 30 MPH, if you hit the pedal it takes a while to clear itself out, for boost to come in, it takes around three quarter throttle, then when boost hits around 20, and the black smoke clears it's fine. H & S did tell me to get rid of the CAI, I haven't, I did clean the MAP sensor, and replace the EBP sensor ran great for 100 miles then right back where it started from. I guess I am just confused. I have a Vortech blown 91 Mustang and never had that throw any codes. I just don't like the fact everyone is blaming someone else, and I'm stuck with something that dont run correctly.
Not defending'm, but at times, it might be important to remember: FOMOCO employees, from the Service Writer level on Up.. CAN'T & WON'T, agree with, or recommend, Any Modifications, or Deletions to their Products*.
If they did.. they wouldn't be working for Ford.. very long ?
Another Good Reason for Forums like SDD.COM ??
:dunno
* However, if we can Worm our way into the Shop area, You may get a Wink, a Nod and some info.. from the PSD Tech's..:sly:D;)
Dogman
tampa,FL
I would put the old air box back on and see if the code come back. I have seen a few post were the air box was the problem.
Yes. If we Mod the intake set-ups.. the Intake Ambient Air Temp sensor/probe thats mounted on/in a Stock air box.. needs to be re-located in, or near Free air.. free from touching anything, or being near anything.. that would give it a Hotter, or Colder temp reading.. than it's design parameters.
i.e, If it sensed a Bogus Cold temp.. It, through the PCM/ECM, might trigger a Cold Start feature, or two. Same/Same with Hot temps.. The PCM/EMC might go into various Modes, to try and correct the [possibly Bogus] issue. Set Codes too. Possibly retain them, if it keeps detecting a bogus issue... continuously.
hetner1102
Austintown, Ohio
Thank You
After months of chasing this problem, the owner of H&S called me this evening. He is saying that the turbo vane position sensor is out of whack. He said they can just feflash the ECM, but recomended replacing it, then having the ECM calibrated to the new sensor. He said the P006B code is either the map sensor or the vane position sensor on the turbos. He said 99% sure the sensor isvthe culprit. Now to find a dealer that will work on m truck with the mods done......anyone know a dealer in NE Ohio? Thanks to everyone for their feedback on my issues, all was very appreciated.m
Hmmmm.. Maybe H & S has it dialed in.. But.. with all your exhaust mods, do you think the MAP sensor could be detecting Over Boost (?), making the ECM try and reduce it.. by sending preset, by design, signals to the turbo vane position sensor ?
A Tune.. to counter that may be possible ?
Just something to Ponder. :dunno
Finding a Dealer to work on it.. may be a Challenge.
