2006 AC Issues
Matt24601
Arlington, TX
I bought a gauge set and hooked it up. Here is what I've got:
Max Cold/Engine Idle
Low Side : 40-45
High Side: 240-250
AC Off/Engine Idle
Low Side: 110-125
High Side: 110-125
Ambient temperature here is in the 90s maybe 100.
I turned stuff off and restarted everything and my max cold engine idle readings changed a little but not dramatically. Low:40, High:225
The reason I started all this is because my system was blowing weak, then it would trickle down to nothing and blow hot. Then I could turn it all off, wait, and turn it back to AC and usually get it to blow cold again. Then it would repeat. While I'm doing these tests it's blowing just fine (go figure). Looking for some suggestions here.
Sent from my SM-G920V using Tapatalk
greenb69
Coshocton ohio
I am just guessing here but is there a vacuum leak somewhere not opening doors on the cooling system.
Sent from my XT1585 using Tapatalk
castellscl
