2020 Ford F-450 10-Speed Transmission RPM's
ravencr
Maryville, TN
Hey guys,
If all goes as planned, I'll be picking up my new 2020 F-450 this week. While I was test driving an XL they had in stock, I figured some folks might like to know the RPM's the new transmission pulls at various speeds.
Chris
ravencr
Maryville, TN
10th gear. Then at the end I manually shifted down while maintaining a steady 74mph.
Chris
hhendrix
Portland, OR
Thanks for the post. I'm a little concerned about the speed/rpm ratio. I have a 2011 6.7 4wd super cab. My speed/rpm are 50/1150, 55/1250, 60/1400. I waited for the 2020 10 speed to order hoping the 10 speed trans would improve mileage. Your tests are much higher speed/rpm ratios. I'm thinking/hoping the F450 has axle ratios that increase the rpm due to load capacities. Do you know what the axles are?
stever01
Ohio
Hey guys,
Chris
What is sticker on one them ?
01yellerCobra
Cali
The 450’s have a much lower 4.30 ring and pinion.
That's what I was curious about. 10th gear doesn't mean much if we don't know what the rear end has for gears.
That's actually better than I thought it would be price wise.
