6.0 shutter at low throttle
:welcome Please fill out your signature so we all know what you drive. Go to the QUICK LINKS in the BLUE LINE, above, and click on Edit Signature. Fill it out and we can better help you. :)
4x4grey88
Nascar Fan #88
Kalifornia
Are you getting a CEL ??? if so, what code are you getting. What you are describing can be a number of things. Does is keep doing it after warm up?
More information is required.
P.S. Welcome to the forum
mantis
NY
Not much help here ,but sounds like the same thing mine is doing.It doesn't seem to change much if it is warm.It doesn't show any codes so that doesn't help.I was thinking injectors,so I used Hotshot.It got worse and then started to clear up,but not like it should be.I guess only time will tell
architect-builder
Jerome, Idaho
Just went through that, also had no codes, it was an injector.
Needs to be diag. with something other than a regular code reader.
B
Nathaniel
Banned User
United States
I think this is a new technology of shutters because i heard first time about these shutters
i have also install shutters but not this is any ways i read out all your posts and take an idea after read your posts about these shutters and planning to purchase these shutters also
jpringle83
WA
What is with the sudden influx of computer trolls on this forum. I've noticed several of this style post and not just on this board.
