Help Needed 911 7.3L diesel down HELP
erichhaag
Haag's HR&C
PA
Hey everybody... I have a 2002 7.3L superduty. It worked on tuesday and wednesday didnt. Cranks with no start and no white smoke out of pipe. I figured no fuel so I opened the fuel filter bowl and drained fuel out. Cranked motor and not filling back up. Heres what I've done thus far: 1. Checked inertia/emergency shut off under passenger kick plate and it is in "ok" position 2. Checked relays under the hood behind battery next to drivers side fender=they all show continuity 3. Checked all fuses relating to fuel pump and ignition = all good. 4. Replaced cam shaft position sensor = brand new 5. Ran a feed from battery to fuel pump and it does run and pump fuel with direct voltage to the pink and black wire.
If anyone has any suggestions before I bite the bullet and send her to the dealer... Erich
When you turn the key On (not cranking).. can you hear the fuel pump running ?
Battery posts & clamps nice and clean ?
erichhaag
Haag's HR&C
PA
no power to fuel pump...not running when key on...I took a hot wire down from battery to see if i could hear/ make it run and I did. not running on its own though via key turned on.
erichhaag
Haag's HR&C
PA
new optima batteries...no corrrosion etc. as I put on di-electric grease
Hmmmm.. Sounds like a fuse or relay.. check all the fuses ? Replace the related fuse for the fuel heating element, disconnect the fuel filter bowl heating element.. at the bowl.. if it starts.. you have a shorted element.
