wernerco
there are no codes and the check engine light comes on and the engine startes to run rought after runnning for a short time the check engine light goes off and runs smooth
When the CEL comes on it has set a code in the PCM, what are you using to try to read the code?
BJS, try this (its in spanish but has some specifications)I may be just being internet retarted but I still am having difficulty finding a model 2008 on OTC's website
Would you link me to the one you have and I'll try to figure out if it is capable of communicating with the PSD. Keep in mind that the PSD is not 100% OBDII compliant even though it has an OBDII plug. it exceeds the GVW for required compliance.
An easy way to determine if it will pull the codes is to intentionally trigger a CEL & code by unplugging the EBPV sensor or MAP sensor and see if your scanner will read the code.
