Question A/C Not Working on 2001 F250 PSD
cpadolf3
US
Sorry to post this on the power/performance thread. Not sure where else to put it. Yesterday, I left my truck running for about 5 minutes while I was doing something in the house. The AC had been working all day, and I had it on Max/Cold. I came back out and noticed it felt warm. Placed my hand in front of the vent and realized it wasn't blowing at all. Moved the switch around a bit, even tried heat. Nothing. No air will flow out of the vents, regardless of what I do. What could this be?
Sent from my SM-N910V using Tapatalk
79jasper
El Paso, TX
Well usually you can start with checking the fuses.
Next highly likely culprit would be the blower motor resistor.
cpadolf3
US
Do you know which fuse it is?
79jasper
El Paso, TX
Couldn't tell you.
Look in the owners manual if you have it.
Probably fuse 20 or fuse 21. These are switched from the ignition as the AC only works when the truck is running.
cpadolf3
US
Thank you very much! All fuses appear to be good. Should I move to the resistor at the fan motor itself?
cpadolf3
US
Wouldn't I need a specialty wire harness?
I would use test wires with an alligator clip on each end. It is just to test it and see if it runs or not.
jarrburg
