Air dog
devgru2011
Jacksonville, Fl
So far, i have deleted my EGR, a Banks Cold Air, and a 4" exhaust with a CAT delete, I'm looking to add some stuff for my fuel system.
1) The AirDog kit AirDog II DF-130/75
2) And the Regulated return kit ITP 6.0L Regulated Return Kit
My first question is can I do both or should I get one or the other?
#2 is that I am very worried about blowing head gaskets. I havnt had any problems but im worried that if I do anything more from where I am now, I can run the risk of blowing them since I have not installed the new head bolts yet and probably wont for a while since it is so expensive.
Any suggestions?? :dunno
HeavyAssault
King William, VA
Unless you have a tuner of some sort don't worry about head studs just yet. The AD II has a regulated pressure output already so the ITP kit isn't needed at all. I suggest you swap in some larger banjo bolts and a fuel pressure gauge. This will allow you to know what is really going on with the fuel pressure. Order the AD after you get a handle on the OEM pump is doing for fuel pressure. If you have no symptoms of puking or just wait on the studs.
