Air filter gauge thingy
iracemine
black and tan
Cheese Curtain
does that littil clear thing work???. my filter has been black as can be and it has never moved! I removed it once and checked it manualy to see if it works, but it does. How dirty does the filter need to be for it to move or better yet how long do you guys wait to change your stock filter????
please any info is better than a veiw:thanks
bbressler
Happy, TX
I would say that gauge doesn't work... As you have noted, it's way past being replaced before the gauge ever reads anything.
When I had the stock setup, I'd check it every other oil change or so (more frequent if driving in dusty conditions) and replace accordingly.
Now, with the DIY Conical filter, it's a quick glance when checking oil to know when it needs to be replaced.
White Buffalo
TDP Pit crew
Fort Sill, Oklahoma
With the description you posted it sounds like your filterminder might be busted. I change my air filter about every 20K miles, but it is entirely dependent on the dust & driving conditions you experience.
Wingdog
Thunder Bay, Ontario
I must say I would not go by those at all. I tested the one one my 97 chev and the only time it showed "the filter was clogged" was when I put my hand over the intake slowly and then finally stalled the motor. I don't think that the ford ones would be much better.
