AMSOIL BYPASS SYSTEM
jerzydiver
Hillsborough NJ
For those interested.
BMK11 mount kit
EAP 110 ea filter (large filter)
bk 1102 all oil filler cap
bk 1101 all oil filter cap
2 bp 242 90 degree elbows for oil caps
Complete kit ready to install 380.00 delivered to your door. pm me if interested!.
Thanks Dennis
Rhino Kustoms LLC
Ken1
Mississippi
I copied this style of install and at this point very pleased with results. Thanks for sharing your ides.
Buffs F-350
New Jersey U.S.A
If I might ask how much it cost and where did you get it. Also did it come in a kit or did you have to piece iy together. Im just thinking about doing the same setup.
Ken1
Mississippi
When all said and done its around $410.
The AMSOIL BY Pass kit was about $350 wholesale and the hoses were #4's 8 feet in lenght.
PM me if you was more details
Ken1
Mississippi
I pulled out my invoice for the above BY Pass System
BMK -11 ByPass Filter mounting kit $130.50
BK1101 Alum Filter Cap $ 95.00
BK1102 Alum Oil Fill Cap $ 50.00
EABP 100 Absolute Efficiency By Pass Filter $29.45
Freight $8.30
Sub Total $320.25
Tax $ 29.64
Total $349.89
In additional I went to a local hose shop to get the SS #4 hoses (2) in 8' length cost $62.00 or a Grand Total of $411.89
This should be my last oil change on only change filters once a year since I only drive about 25K per year.
FYI
This is my second time using AMSOIL BY PASS systems. My old 2001 "X" had the BMK16 system and had two oil changes in 213K or 7 years.
Hope this helps with your question plus the above is wholesale cost. If you need additional info please send a PM
Ken
when you change the filter on the bypass, do you ususally have to add some oil?
F350DRW1
Waylon Fan
N.J.
Good question. next question: How do you know how much to put in after a change, allowing for the extra volume in the lines and the by-pass housing?
Ken1
Mississippi
Yes when you change filter you will need to add make up oil. I am new to the 6.0 engine but my dipstick is down about 1/8" I do not know how much makeup oil to add. This 1/8" is after sitting all night on a cold engine. But really I am not worried about 1/8" low on oil.
Maybe someone here with know how much oil to add when to makeup 1/8"
Ken
F350DRW1
Waylon Fan
N.J.
But won't the added hoses, filter housing, etc. need a certain amount more oil because of the crankcase volume lost to these items? I would imagine that amsoil mentioned it in the installation instructions?
Ken1
Mississippi
Yes, the system does require additional oil but at this point my dipstick is reading 1/8" low. I was planning to wait for a lower reading on dipstick before adding oil. It is possible that the system had some amount of oil above dipstick gauge.
As I stated before still adjusting to 6.0 and dipstick reading.
Ken
