axle wrap
iracemine
black and tan
Cheese Curtain
Hello.
I am gradually getting more and more noticeable "bounce" from a stand still starts. I am leaning towards it being axle wrap. Is this a sign of the shocks need replacing?? or do all SDs do this and im just getting more and more pissed at it????
The trucks got 120K on it and I think stock shocks. all I know is the one bounce test for shocks and..... its hard to get this thing to move!!!! but on road it rides fine.:dunno
all bushings seem fine drive shaft has no play. If I took the shocks off is there a bench test I could do????
Hello.
could be..
slapper bars are the cheapest "cure."
good shocks will help but will not cure the problem
if this is a new phenomenon then double check your spring packs to see if there is a spring cracked.
What kind of driving conditions are you seeing the intolerable axle wrap under?
iracemine
black and tan
Cheese Curtain
slap bars??
empty its just annoying. loaded it feels like the car is rolling back and forth on the trailer and then catching really hard (its not).
PStroked444
FL-Leesburge
Could be the slip joint on the drive shaft. I think it is called slip yoke?? A little cleaning then some grease an no more thunking. JMHO.
slap bars are like these that bolt up to the bottom of the leaf spring at the axle and then allows a certain amount of axle wrap until the bar "slaps" the leaf spring to stop the wrap.
Is this under normal driving or are you getting on it hard? if it's normal day to day traffic driving then it's not axle wrap unless you have broken springs. It's somewhere else in the driveline.
Known problems that would trigger the problems similar to what you're describing.
-Rear pinion bearing loosened (torque to spec there is a crush sleeve to set bearing preload)
-Universal joints
-axle hanger bearing (bushed in rubber and rubber wears out)
yeah, I have to do something with mine, and SOON.
it bangs so hard every time I leave a stoplight..
