boost gauge install question
Shiftin 6.0
which is the best way to install a boost gauge and why, tee into the map hose or drill/tap the elbow? I was planning on teeing into the hose (easiest) but wasnt sure if there are any downsides to doing it that way.
CSIPSD
Bend, OR
The drill and tap is best on the 6.0, I dont know why but the Map line makes the Boost gauge flutter a bit for some reason. Its a bit more diffucult but once done it looks better!
Shiftin 6.0
thanx, much appreciated. is there a gasket between the elbow and manifold and if so is it reusable?
