Question cold start and ICP
butch2000
michigan
does a bad ICP sensor effect how it would start cold ? since the ICP code started it has been hard to start cold ?
What year of truck are you talking about? Probably the FICM as the ICP does not generally cause problems with the 6.0 engine starting.
That is the ICP sensor low code. I am not familiar with that one. Maybe some one will have an answer.
Smoky
Mississippi State
if you plug the truck and warm it up overnight, does it crank ok? if it does you have a FICM issue. If so contact Ed at FCMrepair.com
