Question Convert to power windows and door locks.
97powerstroke7.3
Talbot Co. Maryland
Has anyone converted the OBS powerstroke's doors to power windows and door locks from roll-up windows and non-power door locks?
Please HELP!!!!
They made them for a 1997 truck. My '93 had them. Find a good junk yard and get the parts to convert it. They should know what you need.
94f450sd
certified nutjob
plymouth,ma
you need every wiring harness in the cab including the dash harness out of a truck with a stroke in it for the dash harness.unfortunately ford was retarded where chevy was smart.on a chevy all that was needed was the wiring from door to door and plug it in to the fuse box.
foxman
Upatoi, Georgia
Yes, the Foxman has done this! Not very hard. Find a donor truck and get the harness out of both doors. Then get the harness that runs from door to door - It is located just under the windshield and above the heater box. A real bear to remove if the dash is still in the trk. You will have to add two wires feeding the plug in the left kick panel, - one hot with key on and one hot all times. In about 4 or 5 hours you can have it done.
Foxman
