Coolant fluid????
police stroker
Dallas, Texas
Hey guys just got done last week adding the anti-cativation fluid in but checked the fluid today and its still low. My truck has the green fluid 2000 7.3 was wondering if any special coolant I can add or is water ok???
I usta use any of the the 50/50 pre-mixed coolant that sez it meets the Ford Specs, on the jug. (IIRC, Prestone did)
You can use/add water but it'll dilute the mix ratio, some.
Ever think about switching to the Gold coolant ? I did ;tu. Good stuff.. No additive issues now.:sweet
02stroker
Gratz, Pennsylvania
You might want to use distilled water. Tap water contains minerals that will lead to scale buildup in you'r cooling system. Around here distilled water is around $1 a gallon. Cheap little bit of insurance to help you'r truck live longer. And X2 on what Big Joe said about the gold coolant.
