Question Cranks along time
TexDiesel
Dickinson TX
7.3 have to crank along time before it will start could it be hpop going out it has 300000 miles. Any ideas?
dpantazis
#12
under the cheddar curtain
It could be anything. Seek professional diagnosis.
How is you oil level otherwise.
Low pressure oil pump feeds the hpop. There is s check valve in there too.
Could be as simple as a $10 part.
dieing batteries, glow plugs, gpr, corroded cables, weak starter, ect....
What he said.. would be the things to check & eliminate first ?
But.. it takes 500 psi HPOP pressure, minimum, to pop the injectors @ start-up. A good Scanner would detect that. (ICP pressure, while cranking)
jarrburg
