Question Cruise control shuts off
LAPLANT
Flowood MS
I can set my cruise and within 20 seconds or so it kicks off
any ideas
99 f250 4x4 super cab built 2 of 99
any ideas
Fer starters.. you could replace the VSS (Vehicle Speed Sensor). It's located on the top of yer rear Dif. $25.00 part, 20 minute fix.
Being a 99.. I'd bet yers is Weak & Dirty.. from normal wear ?
LAPLANT
Flowood MS
thanks for the advice i will pick one up this week
I hope I don't bother yall with my questions but I am A mechanic by trade and this is my first diesel just tryin to learn from people that have already been down the same road
OOOPs..:sorry Didn't know you were a Mech.. Whenever I respond to a Post, I try and word things so even the inexperienced can pick up on something. Gets to be Rhetoric at times, but......
Don't be offended by my "DUH" info ??? :lmao:lmao
LAPLANT
Flowood MS
IT'S ALL GOOD jOE AND i WANT TO THANK YOU FOR YOUR HELP I HAVE BEEN WELL OVER 600 HORSES ON GASOLINE THINKING I WANT AROUND 500 IN THIS TRUCK AM I TO FAR OUT OF LINE THESE OIL BURNERS ARE STILL NEW TO ME I GOT TIRED OF 6 MPG IN MY 97 GMC 1/2 TON ON 40'S IS THERE ANY WAY THE ZOODAD AND EVERY OTHER MOD I MADE CAUSED THE CODE
;tu
What other Mods have you done ?
The ZOODAD should'nt have any impact on the CC.
"rooster" has a point... give that a wiggle.
LAPLANT
Flowood MS
Oops
I WAS ON THE WRONG TREAD WHEN I ASKED IF THE ZOODAD MOD ,k&n AND STRAIGHT PIPE COULD CAUSE A CODE i MEANT TO POST IT ON THE THREAD ABOUT MYp0470 DTC THREAD
THANKS AGAIN FOR ALL YALLS HELP
If you are a mechanic, then you know that K&N filter is junk. There is a sock that you can put on the K&N that will help it filter better. Or go to another filter system.
