dash gauge mount
mp18d
Truckee, CA
Does anyone know of a mount made for gauges that would attach either up on the headliner or preferably on the dash, forward of the steering wheel.
I dont want to put them on the A piller, I need the grab handle...
Thanks
Mike
hheynow
Señor Aceite de Soja
Northern California
Thanks
Mike
Mine is on the dash above my radio and sold HERE.
mp18d
Truckee, CA
wiring..
Thanks a bunch guys!! Not sure something like that would have existed.
I assume they mount up pretty clean??
Did you wire the gauges up to the factory senders? Oil pressure, water temp, trans temp.....
We are gonna keep the F-350 for a long while so looking for all the edge we can!:)
Mike
hheynow
Northern California
Mike
Yes, with thin screws but I had to drill the dash and remove the radio.
Tranny sender screwed into a pre-existing port.
Pre-existing port near water pump to tee w/sender. Return to degas bottle.
(I have a coolant loop for my coolant filter where the tee/sender is installed).
I don't have an oil pressure gauge but do have boost.
It's tee'd into the map line
CSIPSD
Bend, OR
OBS or a SD???
The under dash is ok, but its hard to see... the overhead is great! as is the dash suround... But the easiest to see and install is the A-pillar...
