DEF Pump
rlaspinall
Calgary/Alberta
Just hitting 125,000 km on my 2011 F350 and had to change the DEF pump. Total cost $1400. They claim it doesn't fall under the drive train warranty. Has anyone had an experience with this.
sagebel
Stock? Pfft!
Albuquerque, NM
I had one replaced at 23,000 miles on my '11 under warranty. Drivetrain warranty usually only covers the big major components.
rlaspinall
Calgary/Alberta
Too bad. If it happens again, I will likely go with the delete kit. I have already changed our 2 NOX sensors as well.
rlaspinall
Calgary/Alberta
Unfortunately, that warranty is over. Hoard to understand why a NOX sensor is still covered when a DEF pump isn't. Both are related to the same purpose.
I would think that would be covered under emissions but you are probably over on miles for that to be warrenty.
X2
:bs Go as High as you can go.. Above The Dealership, through FOMOCO, to see if you could get that $1400 back... or at least Part of it... for the vary reasons you mention.
125K is just a number (?). In 2+ years.. Emission components shouldn't be going South on a $40K+ truck ?
Jus' say'n.
castellscl
