Diesel fuel Leakage
N8tive560
AZ
My truck is currently sitting for about a year now, and finally landed a good paying job so looking to fix up my beast. I would start it in the mornings, but would have to plug it in over night or for about an hour. (even during the summer!!!!!!!!!) which is a lil odd. I replaced the glow plugs. but still had the same issue. even to let it sit for 30 min would be frustrating because it would not start. also I had noticed fuel leaking into the radiator...... Suggestions would be greatly appreciated thank you. :sweet
dboyw
Lancaster, PA
Fuel leak I am unsure about. Hard starting after a year, batteries. I went thought this hard starting for a year until i really checked my four year old batteries, and found I had a dead cell in one.
More info on your truck will also help in the diagnosis.
A/Ox4
Ventura, CA
What kind of truck?
You said fuel in the radiator? I find it hard to believe you opened your radiator. What do you actually mean?
N8tive560
AZ
Correction not in the radiator haha. Inside the engine coolant recovery tank. I have a 2002 F-250 Super Duty Long Bed 7.3L. 2WD
snicklas
Super Moderator
Staff member
Greenfield, Indiana
If there is fuel making it into the coolant, he could have an issue with the injector cups. I know someone who kept having coolant overflow, but it smelled like diesel. Found out he had a bad injector cup that was allowing fuel into the cooling system.
N8tive560
AZ
I was doin research myself also and all signs lead to the injector cups. a buddy of mine only replaced the injectors here I thought he would have changed the injector cups also...I seen him change it out it didn't seem too hard, I think im able to do it myself.
