difference between dually axle and single wheel???
96EDGEpsd
Welding/Fabrication
New York
i was just wondering wut it would take to make my f-350 single wheel a dually, i just got a flatbed and i need some more wheels to stick out the side...can i just get different drums????
RoyBoy
Diesel Dork
central WI
96EDGEpsd said:
i was just wondering what it would take to make my f-350 single wheel a dually, i just got a flatbed and i need some more wheels to stick out the side...can i just get different drums????
No, you need either Arrowcraft
Or use a complete dually axle. The wheels will hit the springs without the spacers.:sweet
96EDGEpsd
Welding/Fabrication
New York
hmmm, those things dont look cheap...looks like im on the hunt for a junkyard axle
RoyBoy
Diesel Dork
central WI
They weren't the worst, I got a full set up, front and rear spacers, 4 alcoa hot shot wheels and 3 steel for $1617 delivered. Of course they sold to me a dealer price, I have a repair shop :sweet
94f450sd
certified nutjob
plymouth,ma
what did the flatbed come off of?a cab/chassis?or a pickup that somebody took the bed off and replaced it with the flatbed?
if it came off of a cab/chassis truck you will need the cab/chassis rear end as a true dually rear end will be way to wide,the tires will hang out the sides of the bed.
2 more tires and wheels;)
:sorry , i couldn't resist. :D
96EDGEpsd
Welding/Fabrication
New York
i was told the bed was off a 1ton single wheel ford, it measures 7 feet wide, if i got the spacers how much wider would the wheels stick out?? it might be too far:dunno
Gubni
Newbie
Northeast TN
Get one junkyard dually rim and put it on and see if it hits. I've heard a 1" spacer will do.
94f450sd
certified nutjob
plymouth,ma
if it came from a SRW truck then stay SRW as the duallys will stick out the side.another thing did it come off a pickup that somebody removed the box and replaced with the flatbed?or did it come off of a cab/chassis truck that came from the factory with no bed to have a commercial body put on it?
if it came off of a cab/chassis truck it may not fit you frame properly.you may have to lengthen or shorten your frame for it to fit right.
