Dome/cargo light no worky
AK Rover
Kenai, Alaska
I was putting my front dome light housing back in tonight and shorted the light to ground. Is there a fuse for the dome lights? Could I have sent a spike through both dome light bulbs and my cargo lights and ruined them all? I've looked in the manual and can't find anything. The map lights that are controlled by the switches on the housing still work.
Any input greatly appreciated.
yep..
can't tell you which one it is, but it's probably under the dash..
AK Rover
Kenai, Alaska
Fuse #35 under the dash. It's marked as instrument cluster in the owner's manual. Only pulled about a dozen wrong fuses before I found the correct one.
